Will an 11 Speed Chainring fit the Shimano 12 Chain?
Looking to upgrade to Shimano 1x12 speed drivetrain groupset. I want to keep my 30t chainring from my current 1x11 up front.
I can get the microspline conversion kit for my hub so I know that will work.
Just need to know if the chainring is compatible with the 12 speed chain?
Any guidance will be appreciated.
Thanks
1 comments
Hey! I'm afraid Shimano says an 11-speed chainring won't work with the new 12-speed chain - I'm 99% sure this is because they're slightly different internal widths. You can check Shimano's giant compatibility chart here for stuff like this.
I suspect that in the real world you *might* be able to get away with it, but a much better option might just be to buy an aftermarket 12-speed chainring that'll fit your cranks - there are some good options around now - I'm pretty sure Absolute Black does a fairly expansive range. Hope this helps!
